Hello together,
I have the same problem and played a little bit with this function. The problem is that it doesn´t become clear to me.
My procedure is the following:
1. I create two nodes
2. I create a Material Type: isotropic, card image: MAT1, named 'Stahl', E: 2.1e+05 NU: 0.3
3. Create property, type: 1D, name: 'Kette' Card Image: PGAP, assign material 'Stahl'
But then there is the card image and I already read the help but I don´t unterstand it. Could be that my english is too bad for that. When I leave all options the standard ones I only get errors at the end. I would like to model a chain which is a little bit elastic.
Is there anyone who can help me?
Thank you so much!
Sebastian
Hi Sebastian,
1) First create a CGAP (1D>> gaps) element
2) Apply PGAP property to the CGAP elements.
3) Card edit the CGAP element and change the CID option to FLIP as shown in the image attached.
Thank you for your reply, I have done this steps. When I run OptiStruct in this configuration I get an error:
Hi AsahelM.
You can use GAP elements to model cable(s).
In Optistruct you can make use of CGAP elements to capture this behavior.
Please refer to help for more information.
