SPCD displacements
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I used 'fields' to transfer displacments and rotations from a model with a coarse mesh to a model with a fine mesh.
There are different Interpolation Options available.
How can I read (show) all displacements/rotation in the createted SPCD's (maybe in a table) before solving?
1 - 5 of 51
    Altair Employee
    OP
    Hi Oli,
    Do you want to show/label displacement/rotation values on GUI for SPCDs?
    Altair Employee
    OP
    Yes, like in the Picture below. I want to see the displacements/rotations for all SPCD's in one load collector. I just know how to display a single one. Would be great to have get table with all dis/rot from one load collector.
    Altair Employee
    OP
    Hi,
    I will check if there is a script which can do that.
    Altair Employee
    OP
    Hi Oli,
    Unfortunately I couldn't find a script to write out SPCD data to text file or some other format.
    You can either write your own script or get from .fem file
    User: "tinh"
    Altair Community Member
    Updated by tinh
    This template may help (run by command *usercheck spcd.tpl spcdout.csv 0)
    file spcd.tpl:
    *loads(3,2,'SPCD')
       *format()
           *string('SPCD,')
           *field(integer,collector.id,0) *string(',')
           *field(integer,location.id,0)
           *if([comp1!=-999999.0])
                *string(',1,')
    *field(real,comp1,8) *end()
            *endif()
            *if([comp2!=-999999.0])
                 *string(',2,')
    *field(real,comp2,8) *end()
            *endif()
            *if([comp3!=-999999.0])
                 *string(',3,')
    *field(real,comp3,8) *end()
            *endif()
            *if([comp4!=-999999.0])
                 *string(',4,')
    *field(real,comp4,8) *end()
            *endif()
            *if([comp5!=-999999.0])
                *string(',5,')
    *field(real,comp5,8) *end()
            *endif()
            *if([comp6!=-999999.0])
                 *string(',6,')
    *field(real,comp6,8) *end()
            *endif()
    *output()
