Importing Loads from MotionView
Hi Community,
see following link for my problem...
https://community.altair.com/community?id=community_question&sys_id=8076043a1b2bd0908017dc61ec4bcb10
To summarize, I'd like to export Loads from MotionView and import them into Hypermesh, to see and calculate stresses and accordingly optimize the part with Optistruct.
I extracted the forces (with the help of tutorial MV-3030) but I am unable to import them in Hypermesh.
what should I pay attention to when exporting and importing the loads? Are there any tips and tricks to get it working, e.g. regarding the model file (see error in my previous topic)?
Is there a special procedure how to do that?
Thanks in advance for your help.
Regards
Flo
but they were not attached to anything I guess
To realize that, you can find the attached element to the loads (Shift+F5)
If it does, You can try to replace (F3) the applying node of forces to the desired nodes (Dependent/Independent node of RBE3/RBE2). If can't, try to add a tiny mass element every nodes before you replacing.
Hoping this can help you.
Hi Community,
is there anybody who is able to help me?
I tried to import the Loads, it was successful, but they were not attached to anything I guess, if I run a calculation the result is zero, so I think the Loads aren't attached to the components / nodes. Do you know how to realize this?
Further I also summarized some Loads into one load with card image 'LOADADD', but that was still not running.
Thanks in advance for your help and best regards,
Flo
