🎉Community Raffle - Win $25
Join and Win
TCL command to Reduce dependent nodes count and update the washer mesh accordingly
User: "sanket_patil"
Altair Community Member
Updated by sanket_patil
Hello All,
I want to reduce number of dependent nodes of rigid to 6 and update the rigid, washer ring mesh and surrounding mesh accordingly.
Lets say in above snap, it is having 16 dependent nodes and 4 washer rings. So i want to reduce the dependent node count from 16 to 6 and update rigid. and remove 3 washer rings and update mesh accordingly.
Please guide me to do this using TCL commands.
Thanks in advance.
Regards,
Sanket Patil
1 - 7 of 71
    OP
    Hello All,
    Can anyone suggest the commands?
    Regards,
    Sanket
    User: "tinh"
    Updated by tinh
    Hello,
    You should use Utility>Geom/Mesh>Add Washer...
    It is easy to modify washers shape
    OP
    Hello Tinh,
    Thank you so much for the help. I have tried it for 6 nodes but i is not changing node count. Please correct me if i am doing something wrong.
    Regards,
    Sanket
    User: "tinh"
    Updated by tinh
    Did you delete attached rigidlinks prior to modify the washer?
    OP
    yes. i have tried add washer after deleting rigidlink
    User: "tinh"
    Updated by tinh
    Hi,
    they (script's authors) choose original density if it is > new density
    I don't know why they want that!
    But you can pass it by run this command before click on button "Add":
    set ::fepre::AddWasher::params(edgeNodeNum) 6
    And if you want to embed the codes into your script, use these commands:
    *createmark nodes 1 $a_node_hole1 $a_node_hole2 ... *createstringarray 2 "layer_number = 1 uniform_layers = 1 hole_density = 6"  "1 $washer_width" *add_multi_washer_elements 1 30 1 2 0 0 1 1
    OP
    Hi,
    Thank you so much tinh :)..!! it helped me a lot.
    Regards,
    Sanket
