hi
i need idea about retriving component id by giving component name....
if any one know the answer,reply ..plz
This is a trickier process in HyperView than in HyperMesh You need a component handle to get the component id from.
You can search through the components in your model to match the name you want to the 'Label' which you can retrieve using a command such as:
set compname_test [comphandle GetLabel]
and once you know which component handle matches the one you want, you can get the ID number using
comphandle GetComponentID
