🎉Community Raffle - Win $25
Join and Win
remove entries in the gui
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi all,
every time when i run the same script for the second,third... times ,the previous entries are displayed by default as highlighted in the below snapshot.i want to clear these entries each time i run .
thanks in advance
regards,
JAMIE
1 - 3 of 31
    Altair Employee
    OP
    You can clear highlight in a tk entry widget with pathName selection clear. If you want to clear text in an entry widget, use pathName delete 0 end.
    Altair Employee
    OP
    HEY akitoguc
     its not working....
    User: "tinh"
    Altair Community Member
    Updated by tinh
    when you created the entry widget, i am sure that you give it a -textvariable option,
    example
    entry .entOutputPath -textvariable varOutputPath
    then you can clear it by
    set ::varOutputPath ''
