Stress results after optimization
Hi together,
I am using V13 student edition at home. When doing an opimization (e.g. topology) I can only take a look at the optimization results (e.g. density, thickness, shape, ..) but NOT click to the next page to see the analysis of the result (e.g. static displacement after x iterations, stress after x iterations).
It's written that it's page 1 of 1. When using Hyperview at my University I can take a look at other pages. Then I have more pages 'loaded'.
Is the reason, that I use a student edition? Any ways to access the other results?
Thanks in advance!
Hi,
Yes, this is one of the limitations of Student Edition over full suite.
You can load the other h3d files written in the analysis working directory (filename_s1.h3d) to view the analysis results.
