Elements control over automatic Penetration / Intersection fix
Hi All,
I have 2 components A & B where I have found penetrations. when I use Automatic Penetration fix, the elements of component B are getting adjusted. The problem is I want elements of B to be unchanged. Can I have control over one component alone (in my case on A) so that elements of only that component can be reorganised?
HI Ushay,
In RADIOSS user profile you can easily fix one component and move other for fixing penetrations, but using manual methods.
Please go through the below post which shows the same operation.
In HyperCrash you can do this operation in Automatic fix option.
hi all
I am using HM14. i want to hide self penetration for an assembly. How can i hide ?
For my assembly more self penetrations are coming which will take more take if i check manually.
Hi Ushay,
Which user profile are you using?.
In penetration tool, user can select the elements to be moved manually and can move.
