1 - 3 of
31
*findmark surfaces 1 113 1 lines 0 2
Please check the help page of *findmark for details on the third parameter (here 113)
Hello Stefan,
When I check the HM v10 help, I find the third parameter for *findmark is 'function' & has permissible values of 0 & 1. Could you please provide further details regarding you use of the values 113.
Thanks,
Paul
For surface edges (not lines) you can use this:
*createmark surfaces 1 ...
This gives you in mark 2 (hm_getmark lines 2) the edge IDs.
Regards
