🎉Community Raffle - Win $25
Join and Win
Contact analysis: non convergent
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi. I have been trying to perform a non-linear quasi-static analysis to simulate a contact but it doesn't by any means converge. I don't understant the reason. Could you help me? Thank you. This is the file: https://www.dropbox.com/s/asybtschpa1fpsk/compito_2_13.hm?dl=0
1 - 26 of 261
    Altair Employee
    OP
    Hi Mirino,
    please include the following PARAM card.
    Control Cards>> PARAM>> EXPRTNL>>CNTSB and run the analysis.
    Altair Employee
    OP
    Hi Prakash
    thank you for answering. I have tried including that card but it still doesn't work.
    Altair Employee
    OP
    Hi Mirino,
    I shared the modified deck with you, please run the same at your end and check if you are through the error.
    Altair Employee
    OP
    Thank you Prakash, I will try and let you know.
    Altair Employee
    OP
    Hi Prakash, obviously the file you shared with me works. However, I tried activating the cards EXPERTNL and CNTNLSUB and I also tried setting in the NLPARM card NINC=25. However, It doesn't converge. What are the changes you made?
    <?xml version="1.0" encoding="UTF-8"?>post-37159-0-50431200-1433834685_thumb.p
    <?xml version="1.0" encoding="UTF-8"?>post-37159-0-81919800-1433834687_thumb.p
    Altair Employee
    OP
    Mirino,
    Can you remove CNTNLSUB and change the EXPERTNL to CNTSTB instead of YES?
    Altair Employee
    OP
    Hi Prakash
    I'm using Hypermesh 12.0. Inside Control cards-->PARAM I have between many options EXPERTNL and CNTNLSUB. Inside EXPERTNL, I can only choose between YES and NO. The same thing for CNTNLSUB. What am I going to do?
    <?xml version="1.0" encoding="UTF-8"?>post-37159-0-37568700-1433841493_thumb.p
    Altair Employee
    OP
    Mirino,
    could you please let us know what are all updates you have?
    You can find the software updates and graphics information from HyperMesh>> Help>> Updates and system information
    http://forum.altairh...n-your-machine/
    CNTNLSUB is for continuing non linear subcase  from a preceeding NL subcase.
    So, it is not necessary for you as you have only one subcase.
    Can you try with EXPRTNL>> YES and without CNTNLSUB?
    Altair Employee
    OP
    Hi Prakash, I have tried activating only EXPERTNL and not CNTNLSUB, but it still doesn't converge.
    <?xml version="1.0" encoding="UTF-8"?>post-37159-0-13429900-1433852111_thumb.p
    Altair Employee
    OP
    However, I have fixed the problem in another way. I opened the file.fem with an editor (Notepad) and I wrote in at the certain point this line:
    PARAM,EXPERTNL,CNTSTB
    And actually it worked finally.
    On the other hand, since I had the same problem (non-convergent analysis) with another model, I tried to insert again PARAM,EXPERTNL,CNTSTB. This time it didn't work: LOAD STEP 0.1, 0.2, 0.3 ..., 0.9 were convergent, while LOAD STEP 1.0 wasn't.
    Here's the file: https://www.dropbox.com/s/zl54bn18nfpqs4d/supporto_09.hm?dl=0
    Subcase         1
      LOAD STEP: 1.0000
                   Nonlinear Error Measures  Gap and Contact Element Status  Maximum
     Iter Avg. U    EUI      EPI      EWI    Open Closed Stick Slip Frozen  Plststrn
      1  6.23E+01 9.90E+01 5.95E+04 5.95E+04   230   230     0     0     0  0.00E+00
      2  9.64E-04 5.34E+06 4.49E+01 4.39E+05   336   124     0     0     0  0.00E+00
      3  1.22E-03 1.27E-01 4.58E+01 1.03E+01   334   126     0     0     0  0.00E+00
      4  1.40E-03 1.73E-01 4.56E-03 7.17E-04   372    88     0     0     0  0.00E+00
      5  1.39E-03 1.06E-02 2.95E-03 8.20E-05   398    62     0     0     0  0.00E+00
      6  2.73E-03 1.47E+02 3.73E+02 5.49E+02   400    60     0     0     0  0.00E+00
      7  1.39E-03 1.19E+00 5.65E-03 5.09E-03   420    40     0     0     0  0.00E+00
      8  1.14E-03 2.15E-01 1.16E+02 2.54E+01   410    50     0     0     0  0.00E+00
      9  1.17E-03 1.89E-01 5.38E-04 3.41E-05   434    26     0     0     0  0.00E+00
     10  1.29E-03 1.15E-01 1.01E+00 5.55E-02   436    24     0     0     0  0.00E+00
      No convergence after   10 iterations
      Expert: Continue iterations
     11  1.30E-03 8.46E-03 2.10E-05 2.40E-07   448    12     0     0     0  0.00E+00
     12  4.52E+01 9.90E+01 7.05E+03 7.05E+03   246   214     0     0     0  0.00E+00
     13  5.79E-04 5.79E+06 3.92E-02 2.58E+03   398    62     0     0     0  0.00E+00
     14  5.23E-04 8.98E-01 8.69E+02 9.14E+02   370    90     0     0     0  0.00E+00
     15  3.18E-04 3.31E-01 1.57E-02 1.32E-02   402    58     0     0     0  0.00E+00
      No convergence after   15 iterations
     *** ERROR #  157 ***
     Error opening the scratch file './supporto_09_1992_s44.rs~'
        Fortran error code =          9
        This may be caused by not having the access right to open the file,
        not enough memory left for the system routines, or some other
        system setup related reasons.
     This error was detected in subroutine opseqscr.
     *** ERROR #  158 ***
     Error encountered when accessing the scratch file.
        error from subroutine 'xdslrs'
        Solver error no. =       -702
        This may be caused by insufficient disk space or some other
        system resource related limitations.
     This error was detected in subroutine bcsprefct.
    !! NONLINEAR SOLUTION FAILED TO CONVERGE FOR SUBCASE 1 !!
     Large nonlinear error - no solution saved.
          Moderate error: saved the last iteration to results
     This error occurs in module 'nlstatdrv'.
    RESOURCE USAGE INFORMATION
     MAXIMUM MEMORY USED                                       337 MB
     MAXIMUM DISK SPACE USED                                  1413 MB
    COMPUTE TIME INFORMATION
     EXECUTION STARTED                         Tue Jun 09 18:47:36 2015
     EXECUTION COMPLETED                       Tue Jun 09 19:34:44 2015
     ELAPSED TIME                                         00:47:07
     CPU TIME                                             00:45:50
     *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                            ***** END OF REPORT *****
     For Useful OptiStruct Tips and Tricks, go to the URL:
     PROGRAM STOPPED DUE TO ERROR.
     RADIOSS/OptiStruct error termination report printed to file
     'supporto_09.stat'.
     A fatal error has occurred during computations:
      *** ERROR #  157 ***
     ==== End of solver screen output ====
     ==== Job completed ====
    Altair Employee
    OP
    Mirino,
    It can be seen from the out file that upto 90% load the model is stable but beyond 90% no convergence is seen.
    So, please consider reducing the load.
    Altair Employee
    OP
    Hello,
    it looks like there is a io-problem. Take a look at the error 'Error opening the scratch file './supporto_09_1992_s44.rs~' ....
    Please check if there is enough disc space and you have all access rights.
    Regards,
    Mario
    Altair Employee
    OP
    Hi Mario,
    Okay then the issue is with the disk space to write the scratch files.
    Also, it looks like the run fails when 100% load is applied to the model due to the scratch file.
    You may have to free up some memory to get the scratch files written or you can choose a different location to write the scratch files.Please refer to the OptiStruct Run Options (image below)
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-17860700-1433917846_thumb.jp
    Altair Employee
    OP
    Hi. I reduced the force by 10% (from 24N to 21.6N) to match the LOAD STEP 0.9 which was convergent. With this new value of the force however, LOAD STEP 0.9 was convergent, while LAOD STEP 1 wasn't. Then, since the EXPERTNL was activated, the LOADSTEP 0.95 was calculated. The bottom line is:
    LAOD STEP 0.9998 was convergent
    LOAD STEP 1.0000 was NOT convergent.
    (Now I no longer have the problem with the disk space since the error is merely: *** ERROR #  941 ***
      NON-CONVERGENT NONLINEAR ITERATIONS FOR SUBCASE         1.)
    Here's the final steps (from LOAD STEP 0.8 onwards):
     LOAD STEP: 0.8000
      1  1.68E-05 4.88E+01 1.20E-10 8.01E-11   460     0     0     0     0  0.00E+00
      2  1.68E-05 4.38E-16 1.20E-10 5.19E-26   460     0     0     0     0  0.00E+00
      Expert: Adjust parameters and proceed
      Subcase         1
      LOAD STEP: 0.9000
      1  8.09E-05 7.12E+01 3.48E-13 2.77E-13   460     0     0     0     0  0.00E+00
      2  8.09E-05 9.94E-16 3.48E-13 2.53E-28   460     0     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      1  5.61E+01 9.90E+01 5.95E+04 5.95E+04   230   230     0     0     0  0.00E+00
      2  9.64E-04 4.81E+06 4.49E+01 3.95E+05   336   124     0     0     0  0.00E+00
      3  1.22E-03 1.26E-01 4.57E+01 1.03E+01   334   126     0     0     0  0.00E+00
      4  1.40E-03 1.70E-01 4.56E-03 7.17E-04   372    88     0     0     0  0.00E+00
      5  1.39E-03 1.10E-02 2.96E-03 8.22E-05   398    62     0     0     0  0.00E+00
      6  2.72E-03 1.47E+02 3.71E+02 5.47E+02   400    60     0     0     0  0.00E+00
      7  1.39E-03 1.18E+00 5.64E-03 5.07E-03   420    40     0     0     0  0.00E+00
      8  1.14E-03 2.16E-01 1.15E+02 2.53E+01   410    50     0     0     0  0.00E+00
      9  1.17E-03 1.91E-01 5.38E-04 3.36E-05   434    26     0     0     0  0.00E+00
     10  1.28E-03 1.09E-01 7.16E-01 3.77E-02   436    24     0     0     0  0.00E+00
     11  1.30E-03 1.00E-02 1.91E-05 2.64E-07   448    12     0     0     0  0.00E+00
     12  4.06E+01 9.90E+01 7.05E+03 7.05E+03   246   214     0     0     0  0.00E+00
     13  5.79E-04 5.21E+06 3.92E-02 2.32E+03   398    62     0     0     0  0.00E+00
     14  5.23E-04 8.99E-01 8.69E+02 9.13E+02   370    90     0     0     0  0.00E+00
     15  3.17E-04 3.33E-01 1.57E-02 1.33E-02   402    58     0     0     0  0.00E+00
     16  3.02E-04 4.38E-02 8.51E-03 8.07E-04   424    36     0     0     0  0.00E+00
     17  2.97E-04 2.17E-01 2.55E+00 2.05E-01   432    28     0     0     0  0.00E+00
     18  3.46E-04 2.10E+01 5.24E+00 2.47E+00   436    24     0     0     0  0.00E+00
     19  4.14E-04 2.24E+01 5.02E-04 2.01E-04   448    12     0     0     0  0.00E+00
     20  1.10E-01 9.87E+01 1.34E+04 1.33E+04   274   186     0     0     0  0.00E+00
      No convergence after   20 iterations
      Expert: Back off, adjust and retry
      Subcase         1
      LOAD STEP: 0.9500
      1  2.50E-04 6.42E+01 2.36E+02 1.59E+02   433    27     0     0     0  0.00E+00
      2  2.48E-04 8.30E-03 1.76E-03 3.74E-05   446    14     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      1  2.18E+00 9.90E+01 5.86E+03 5.86E+03   228   232     0     0     0  0.00E+00
      2  2.64E-03 7.34E+04 1.68E-02 1.51E+01   424    36     0     0     0  0.00E+00
      3  1.83E-03 3.91E-01 1.40E+00 4.15E-01   442    18     0     0     0  0.00E+00
      4  2.09E-03 1.84E+02 3.63E+03 6.07E+03   362    98     0     0     0  0.00E+00
      5  4.23E-04 3.77E+01 5.76E+02 1.25E+03   380    80     0     0     0  0.00E+00
      6  2.92E-04 3.24E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      7  2.92E-04 3.18E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 7.97E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      9  3.37E-04 2.40E+01 4.98E+00 2.67E+00   436    24     0     0     0  0.00E+00
     10  4.16E-04 2.55E+01 1.27E+00 4.96E-01   438    22     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9750
      1  2.47E-04 1.72E+00 9.14E+00 5.48E-02   440    20     0     0     0  0.00E+00
      2  2.46E-04 1.66E-02 3.18E-12 9.38E-15   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      1  2.15E+00 9.90E+01 5.84E+03 5.83E+03   230   230     0     0     0  0.00E+00
      2  2.67E-03 7.21E+04 1.66E-02 1.48E+01   424    36     0     0     0  0.00E+00
      3  1.83E-03 4.00E-01 1.40E+00 4.11E-01   442    18     0     0     0  0.00E+00
      5  4.23E-04 3.76E+01 5.75E+02 1.25E+03   380    80     0     0     0  0.00E+00
      7  2.92E-04 3.09E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.29E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      9  3.37E-04 2.38E+01 4.98E+00 2.67E+00   436    24     0     0     0  0.00E+00
     10  4.16E-04 2.54E+01 1.27E+00 4.96E-01   438    22     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9875
      1  2.47E-04 3.48E-01 3.35E-12 5.59E-15   440    20     0     0     0  0.00E+00
      2  2.47E-04 1.25E-10 3.00E-12 2.67E-22   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      3  1.83E-03 4.01E-01 1.40E+00 4.11E-01   442    18     0     0     0  0.00E+00
      5  4.23E-04 3.76E+01 5.76E+02 1.25E+03   380    80     0     0     0  0.00E+00
      6  2.92E-04 3.20E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      7  2.92E-04 3.04E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.20E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9938
      1  2.47E-04 2.66E-01 2.67E-12 2.88E-15   440    20     0     0     0  0.00E+00
      2  2.47E-04 3.29E-10 2.86E-12 4.51E-22   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      6  2.92E-04 3.21E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      7  2.92E-04 3.06E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.61E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      9  3.37E-04 2.39E+01 4.98E+00 2.67E+00   436    24     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9969
      1  2.47E-04 3.49E-01 2.45E-12 2.82E-15   440    20     0     0     0  0.00E+00
      2  2.47E-04 3.43E-10 2.54E-12 4.80E-22   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      2  2.67E-03 7.21E+04 1.67E-02 1.48E+01   424    36     0     0     0  0.00E+00
      7  2.92E-04 2.94E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.36E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9984
      1  2.47E-04 6.09E-01 3.16E-12 4.98E-15   440    20     0     0     0  0.00E+00
      2  2.47E-04 2.66E-09 2.70E-12 3.41E-21   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      6  2.92E-04 3.22E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      7  2.92E-04 3.07E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.09E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9992
      1  2.47E-04 1.17E+00 2.65E-12 8.11E-15   440    20     0     0     0  0.00E+00
      2  2.47E-04 1.97E-09 2.45E-12 3.13E-21   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      6  2.92E-04 3.18E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      8  2.85E-04 8.49E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9996
      1  2.47E-04 2.28E+00 3.32E-12 1.46E-14   440    20     0     0     0  0.00E+00
      2  2.47E-04 1.42E-09 3.63E-12 2.30E-21   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      7  2.92E-04 2.98E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.83E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 0.9998
      1  2.48E-04 4.46E+00 2.68E-12 3.24E-14   440    20     0     0     0  0.00E+00
      2  2.48E-04 1.48E-08 3.09E-12 2.49E-20   440    20     0     0     0  0.00E+00
      Subcase         1
      LOAD STEP: 1.0000
      5  4.23E-04 3.77E+01 5.75E+02 1.25E+03   380    80     0     0     0  0.00E+00
      6  2.92E-04 3.25E-01 8.36E-01 3.62E-01   394    66     0     0     0  0.00E+00
      7  2.92E-04 3.28E-02 8.42E-03 8.59E-04   420    40     0     0     0  0.00E+00
      8  2.85E-04 8.66E-02 7.63E-04 5.01E-05   430    30     0     0     0  0.00E+00
      Expert: Terminate nonlinear process
     *** ERROR #  941 ***
     Suggestions:
     (Scratch disk space usage for starting iteration = 1347 MB)
    (Running out-of-core solution)
    Volume                              =  9.56948E+05   Mass     =  7.55989E-03
     Subcase   Compliance
           1  0.000000E+00
     ANALYSIS COMPLETED.
     EXECUTION STARTED                         Wed Jun 10 08:56:19 2015
     EXECUTION COMPLETED                       Wed Jun 10 12:11:31 2015
     ELAPSED TIME                                         03:15:11
     CPU TIME                                             03:07:19
     'supporto_09.stat'.
      *** ERROR #  941 ***
      Suggestions:
      ANALYSIS COMPLETED.
    Altair Employee
    OP
    Hi Mirino,
    Okay, so the model is stable with 99.8% of the load and anything beyond it is not able to converge.
    Altair Employee
    OP
    Hi Prakash. 99.98%. How is that possible and how can I fix this problem?
    Altair Employee
    OP
    Hi,
    it seems to be a contact problem.
    As you can see, up to load 0.9 there is no contact. Then at 1.0 exactly half of the elements (230) are in contact. From this point the iteration has problems (since before there is nothing to iterate).
    Hints:
    please check all your contact parameters
    be sure you know what all the parameters are doing
    i prefer for a normal shell-shell open contact: TYPE=SLIDE, MORIENT=OPENGAP, SRCHDIS=1.5 x distance of contact opening (be sure to have different contacts for different distances) , ADJUST=NO, DISCRETE=S2S for HW13)
    if you have only contact non-linearity (linear material and load), then change NLPARM to:
    NINC=1, KSTEP=1, MAXITER=50
    (try to lower the convergence criteria and take a look what happens)
    Best regards,
    Mario
    Altair Employee
    OP
    Mario,
    Yes, when the parts are in contact there could be stability issues which leads to a non convergent solution at the end.
    Most of the users think that search distance is the distance between parts which have contacts but it is not. As you said one should have to learn what the parameters in the contact card actually mean.
    Altair Employee
    OP
    Hi. I have been able to make the two analysis run. I used a property with card image PCONT and inside NLPARM I set the value as:
    NINC=10
    MAXITER=25
    CONV=UPW
    EPSU, EPSP, EPSW as default.
    To make the analysis run I increased the magnitude of the force. As a result of this, in one of the analysis if the magnitude of the force is <54000N the analysis doesn't converge. If the magnitude is >54000N, the analysis converge.
    Altair Employee
    OP
    Equally, if I want a force with an magnitude less than 55 000 N, setting NINC=1 as Mario suggested, the analysis converges.
    Altair Employee
    OP
    Hi everibody!
    I have the same problem with my simulation. When it starts last iterations i have problem on UPW and after many simulation i really don't know ho to fix it. We tryied first reducing the tollerance on EPSU EPSW and EPSW, then reducing Ksteps (from 5 to 1) and increasing NINC (from 10 to 20).
    After some attempts i decide to reduce load (although is not properly correct for the fisic model that i'm trying to simulate) from 60000 to 10000.
    EXPERTNL and CNTSTB are activate. What can i try to fix this issue?
    Altair Employee
    OP
    HI @Lorenzo Loscalzo
    Can you please share the entire .out file?
    Altair Employee
    OP
    The last analysis is still running
     **                         OptiStruct 2017.1                          **
     **             Advanced Engineering Analysis, Design and              **
     **        Optimization Software from Altair Engineering, Inc.         **
     **             Windows 10  (Build 9200)  DESKTOP-AERLR72              **
     **         8 CPU:  Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz          **
     **                    12189 MB RAM,  21129 MB swap                    **
     ** Build tag: 0862567_9433171_Ce64RBW8UH14M:128708-1  4000000014001   **
     **  COPYRIGHT (C) 1996-2017                 Altair Engineering, Inc.  **
     ** All Rights Reserved.  Copyright notice does not imply publication. **
     **         Contains trade secrets of Altair Engineering, Inc.         **
     ** Decompilation or disassembly of this software strictly prohibited. **
     *** OptiStruct defaults set from:
       install config file: C:\Program Files\Altair\2017\/hwsolvers/optistruct.cfg.
     NOTE # 9199
     MSGLMT=STRICT is active, all messages will be printed.
     You can suppress some less important warning messages by use of
      MSGLMT=BRIEF or UNREF (in config file or in the input data).
     2 PARAM(s) were set:
        AUTOMSET,YES
        EXPERTNL,CNTSTB
     *** WARNING # 4783
     Finite sliding is ignored for contact because there is no large-displacement
     analysis.
     *** INFORMATION # 815
     The total number of rigid elements, whose rotational dependent d.o.f.
     are removed because there is no need to constrain those d.o.f., is 47.
     *** INFORMATION # 3203
     In order to produce more realistic results with nonlinear friction, gap offset
     was automatically set to NO.  This may cause failure of rigid body balance,
     especially on models without SPC support. To activate gap offset,
     set GAPOFFS to YES on the GAPPRM card.
     *** INFORMATION # 3433
     MUMPS solver is used by default for nonlinear analysis at subcase 3.
     The amount of memory allocated for the run is 2461 MB.
     This run will use in-core processing in the solver.
     MUMPS solver will allocate memory separately and may
     run in different core (in/out) mode.
    OPTIMIZATION FILE AND PARAMETER INFORMATION :
      FEM model file               :
         D:/Università/PAC/Progetto motoriduttore/simulazione modello completo/mesh definitiva nuovi contatti linguetta2.fem
      Output files prefix          :
      Model read from files:
    FINITE ELEMENT MODEL DATA INFORMATION :
      Total # of Grids (Structural)        :    870119
      Total # of Elements Excluding Contact:    734147
      Total # of N2S Contact Elements      :     10819 (internally created CGAPG)
      Total # of Rigid Elements            :        54
      Total # of Rigid Element Constraints :      8520
      Total # of Degrees of Freedom        :   2650431
      (Structural)
      Total # of Non-zero Stiffness Terms  : 100563930
      Element Type Information
       CHEXA    Elements   :   692019
       CTETRA   Elements   :    35020
       CPENTA   Elements   :     7092
       CROD     Elements   :       16
      Load and Boundary Information
       FORCE Sets        :         1
       SPC   Sets        :         1
      Material and Property Information
       PSOLID Cards      :         2
       PROD   Cards      :         1
       PCONT  Cards      :         2
       MAT1   Cards      :         2
    OPTIMIZATION PROBLEM PARAMETERS :
     NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
       Static Subcase Summary :
       Subcase ID    SPC ID   FORCE ID
            3            1            2
       Run Type                        :   Analysis Only
       Run at location                 : D:/Università/PAC/Progetto motoriduttore/simulazione modello completo/
       Scratch file directory          : D:/Università/PAC/Progetto motoriduttore/simulazione modello completo/
                                         Free space:   843.359 GB
       Number of CPU processors        :          1
    MEMORY ESTIMATION INFORMATION :
     Solver Type is:  Sparse-Matrix Solver
                      Direct Method
     Current Memory (RAM)                                    :    2461 MB
     (Note: MUMPS Solver Allocates Memory Separately.)
     Estimated Minimum Memory (RAM) for Out of Core Solution :   11671 MB
     Recommended Memory (RAM) for Out of Core Solution       :   11671 MB
     Recommended Memory (RAM) for In-Core Solution           :   55962 MB
     (Note: Memory for MUMPS Solver is Included in Estimation.)
     (Note: The Minimum Memory Requirement is limited by Assembly Module.)
     (Note: Use param,HASHASSM,yes to avoid assembly module memory bottleneck)
    DISK SPACE ESTIMATION INFORMATION :
     Estimated Disk Space for Output Data Files              :     228 MB
     Estimated Scratch Disk Space for In-Core Solution       :    1398 MB
     Estimated Scratch Disk Space for Out of Core Solution   :   45104 MB
    BEGINNING ANALYSIS SOLUTION ....
    ANALYSIS RESULTS :
    ITERATION   0
     Element # 1156, element type PENTA.
     WARNING - Outside of recommended range: Tria Vertex Angle =    10.554
               lower limit =    15.000
     WARNING - Outside of recommended range: Face Skew Angle =    69.419
               upper limit =    60.000
     WARNING - Outside of recommended range: Edge Angle =    79.444
               upper limit =    75.000
     Element # 1157, element type PENTA.
     WARNING - Outside of recommended range: Tria Vertex Angle =    10.558
     WARNING - Outside of recommended range: Face Skew Angle =    69.414
     WARNING - Outside of recommended range: Edge Angle =    79.442
     Element # 1158, element type PENTA.
     WARNING - Outside of recommended range: Edge Angle =    79.440
     NOTE : other similar error/warning messages were suppressed,
            use PARAM,CHECKEL,FULL to obtain full report
     Element # 699747, element type TET10.
     WARNING - Outside of recommended range: Edge Angle =    75.385
     Element # 699828, element type TET10.
     WARNING - Outside of recommended range: Edge Angle =    76.233
     Element # 699876, element type TET10.
     WARNING - Outside of recommended range: Edge Angle =    75.622
     Element Quality Check Summary
     Total # of elements that exceeded recommended range (warning) =   587
     Note: Only element with the highest violation of each check is listed below.
     Recommended range violations:
     Element     Property          # of     Recommended Range    Max.  Viol.  Elem.
                                   Viol.     Lower     Upper    Value  type    No.
     TET10   Edge Angle                 5        --     75.00     76.63  U   699881
     PENTA   Skew Angle               582        --     60.00     72.47  U   328210
     PENTA   Edge Angle               446        --     75.00     81.04  U   328211
     PENTA   TRIA Vertex Angle        446     15.00    165.00      8.96  L   328210
     List of Auto-SPC d.o.f.s for loadcase   3
     Total number of Auto-SPC d.o.f.s = 39099
               Grid No.         Component
                          96664             4   6
                          96665             4   6
                          96666             4   6
                          96667             4   6
                          96733             4   6
                          96760             4   6
                          96787             4   6
                          96790             4   6
                          96793             4   6
                          96796             4   6
                          96979             4   6
                          96980             4   6
                          96981             4   6
                          96982             4   6
                          96983             4   6
                          96984             4   6
                          97019             4   6
                          97021             4   6
                          97023             4   6
                          97025             4   6
                          97027             4   6
                          97029             4   6
                          97031             4   6
                          97033             4   6
                          97071             4   6
                          97072             4   6
                          97073             4   6
                          97074             4   6
                          97075             4   6
                          97076             4   6
                          97077             4   6
                          97078             4   6
                          97079             4   6
                          97081             4   6
                          97082             4   6
                          97084             4   6
                          97085             4   6
                          97087             4   6
                          97088             4   6
                          97090             4   6
                          97105             4   6
                          97106             4   6
                          97131             4   6
                          97132             4   6
                          97133             4   6
                          97134             4   6
                          97135             4   6
                          97136             4   6
                          97137             4   6
                          97138             4   6
        Because of PARAM, PRGPST, 100, Auto-SPC printing is limited to 100 dofs.
            Nonlinear  iteration  summary for    Subcase        3
      Subcase         3  Load step:  5.0000E-02
      1  2.84E-07 9.90E+01 2.41E-01 2.41E-01  8874  1945  1945     0     0  0.00E+00
      2  3.29E-07 1.04E-01 6.99E-03 5.41E-04  9601  1218  1218     0     0  0.00E+00
      3  3.42E-07 2.00E-02 7.89E-03 1.82E-04  9917   902   902     0     0  0.00E+00
      4  3.42E-07 4.62E-04 1.65E-04 2.06E-07 10071   748   748     0     0  0.00E+00
      Subcase         3  Load step:  1.0000E-01
      1  7.47E-07 5.36E+01 1.23E-02 6.54E-03 10204   615   615     0     0  0.00E+00
      2  7.47E-07 2.69E-04 6.95E-06 1.91E-08 10277   542   542     0     0  0.00E+00
      Subcase         3  Load step:  1.5000E-01
      1  1.22E-06 3.82E+01 1.02E-02 3.79E-03 10360   459   459     0     0  0.00E+00
      2  1.22E-06 2.89E-04 2.57E-07 2.70E-10 10411   408   408     0     0  0.00E+00
      Subcase         3  Load step:  2.0000E-01
      1  1.78E-06 3.03E+01 1.39E-03 3.18E-04 10457   362   362     0     0  0.00E+00
      2  1.78E-06 6.52E-04 3.80E-08 5.87E-11 10483   336   336     0     0  0.00E+00
      Subcase         3  Load step:  2.5000E-01
      1  2.42E-06 2.55E+01 4.66E-04 1.08E-04 10512   307   307     0     0  0.00E+00
      2  2.42E-06 1.05E-04 6.41E-06 3.06E-09 10527   292   292     0     0  0.00E+00
      Subcase         3  Load step:  3.0000E-01
      1  3.14E-06 2.18E+01 1.54E-04 2.93E-05 10554   265   265     0     0  0.00E+00
      2  3.14E-06 1.73E-04 2.25E-08 4.18E-11 10568   251   251     0     0  0.00E+00
      Subcase         3  Load step:  3.5000E-01
      1  3.88E-06 1.84E+01 1.88E-05 2.91E-06 10591   228   228     0     0  0.00E+00
      2  3.88E-06 1.50E-04 4.86E-09 1.15E-11 10601   218   218     0     0  0.00E+00
      Subcase         3  Load step:  4.0000E-01
      1  4.61E-06 1.53E+01 1.80E-08 2.35E-09 10624   195   195     0     0  0.00E+00
      2  4.61E-06 8.29E-05 9.75E-07 1.09E-09 10625   194   194     0     0  0.00E+00
      Subcase         3  Load step:  4.5000E-01
      1  5.31E-06 1.27E+01 4.91E-05 6.34E-06 10636   183   183     0     0  0.00E+00
      2  5.31E-06 4.93E-04 3.47E-07 4.43E-10 10637   182   182     0     0  0.00E+00
      Subcase         3  Load step:  5.0000E-01
      1  5.98E-06 1.09E+01 1.36E-04 1.51E-05 10644   175   175     0     0  0.00E+00
      2  5.98E-06 1.91E-04 1.74E-10 8.01E-13 10644   175   175     0     0  0.00E+00
      Subcase         3  Load step:  5.5000E-01
      1  6.62E-06 9.52E+00 2.13E-08 1.72E-09 10674   145   145     0     0  0.00E+00
      2  6.62E-06 4.45E-05 9.46E-10 2.12E-14 10683   136   136     0     0  0.00E+00
      Subcase         3  Load step:  6.0000E-01
      1  7.25E-06 8.52E+00 1.46E-06 1.12E-07 10699   120   120     0     0  0.00E+00
      2  7.25E-06 5.72E-05 5.33E-10 3.67E-14 10706   113   113     0     0  0.00E+00
      Subcase         3  Load step:  6.5000E-01
      1  7.87E-06 7.76E+00 7.48E-07 5.43E-08 10714   105   105     0     0  0.00E+00
      2  7.87E-06 6.05E-05 1.45E-10 2.80E-14 10718   101   101     0     0  0.00E+00
      Subcase         3  Load step:  7.0000E-01
      1  8.48E-06 7.14E+00 1.34E-08 9.34E-10 10728    91    91     0     0  0.00E+00
      2  8.48E-06 5.72E-05 1.04E-05 2.71E-09 10730    89    89     0     0  0.00E+00
      Subcase         3  Load step:  7.5000E-01
      1  9.09E-06 6.67E+00 4.71E-06 3.20E-07 10737    82    82     0     0  0.00E+00
      2  9.09E-06 6.51E-05 9.51E-07 1.37E-09 10738    81    81     0     0  0.00E+00
      Subcase         3  Load step:  8.0000E-01
      1  9.70E-06 6.12E+00 7.56E-07 4.64E-08 10733    86    86     0     0  0.00E+00
      2  9.70E-06 8.04E-05 1.19E-07 2.09E-11 10733    86    86     0     0  0.00E+00
      Subcase         3  Load step:  8.5000E-01
      1  1.03E-05 5.82E+00 1.21E-06 7.03E-08 10719   100   100     0     0  0.00E+00
      2  1.03E-05 2.11E-04 1.44E-07 2.86E-11 10725    94    94     0     0  0.00E+00
      Subcase         3  Load step:  9.0000E-01
      1  1.09E-05 5.55E+00 1.15E-07 6.31E-09 10733    86    86     0     0  0.00E+00
      2  1.09E-05 2.22E-04 3.85E-02 2.34E-05 10702   117   117     0     0  0.00E+00
      3  1.09E-05 2.06E-01 7.34E-05 5.28E-08 10725    94    94     0     0  0.00E+00
      4  1.09E-05 4.96E-05 8.08E-07 3.70E-10 10722    97    97     0     0  0.00E+00
      Subcase         3  Load step:  9.5000E-01
      1  1.16E-05 5.79E+00 3.26E+00 1.65E-01 10428   391   391     0     0  0.00E+00
      2  1.16E-05 5.37E-03 1.05E+01 2.64E-01 10350   469   469     0     0  0.00E+00
      3  1.16E-05 2.59E-03 6.66E-04 4.20E-06 10483   336   336     0     0  0.00E+00
      Subcase         3  Load step:  1.0000E+00
      1  3.89E-05 7.71E+01 2.64E+03 1.26E+03  8374  2445  2445     0     0  0.00E+00
      2  6.87E-05 7.11E+01 2.81E+05 2.81E+05  6168  4651  4542   109     0  0.00E+00
      3  7.87E-05 1.05E+00 2.97E+00 1.40E-01  7541  3278   957  2321     0  0.00E+00
      4  7.58E-05 9.92E-02 4.32E+00 1.10E-01  7475  3344   939  2405     0  0.00E+00
      5  6.70E-05 3.04E+01 3.83E+01 1.48E+00  7396  3423  1016  2407     0  0.00E+00
    Altair Employee
    OP
     NOTE # 9199
        AUTOMSET,YES
        EXPERTNL,CNTSTB
     *** WARNING # 4783
     analysis.
      FEM model file               :
      (Structural)
       CROD     Elements   :       16
       FORCE Sets        :         1
       SPC   Sets        :         1
       PSOLID Cards      :         2
       PROD   Cards      :         1
       PCONT  Cards      :         2
       MAT1   Cards      :         2
            3            1            2
                      Direct Method
    ANALYSIS RESULTS :
    ITERATION   0
               Grid No.         Component
                          96664             4   6
                          96665             4   6
                          96666             4   6
                          96667             4   6
                          96733             4   6
                          96760             4   6
                          96787             4   6
                          96790             4   6
                          96793             4   6
                          96796             4   6
                          96979             4   6
                          96980             4   6
                          96981             4   6
                          96982             4   6
                          96983             4   6
                          96984             4   6
                          97019             4   6
                          97021             4   6
                          97023             4   6
                          97025             4   6
                          97027             4   6
                          97029             4   6
                          97031             4   6
                          97033             4   6
                          97071             4   6
                          97072             4   6
                          97073             4   6
                          97074             4   6
                          97075             4   6
                          97076             4   6
                          97077             4   6
                          97078             4   6
                          97079             4   6
                          97081             4   6
                          97082             4   6
                          97084             4   6
                          97085             4   6
                          97087             4   6
                          97088             4   6
                          97090             4   6
                          97105             4   6
                          97106             4   6
                          97131             4   6
                          97132             4   6
                          97133             4   6
                          97134             4   6
                          97135             4   6
                          97136             4   6
                          97137             4   6
                          97138             4   6
    Altair Employee
    OP
    HI,
    Did the simulation came out with any errors or is it successful?
    Altair Employee
    OP
    it's succesfull
