Is there a way to import geometry from FLUX 2D to FLUX 3D? like just on the XY plane.
Thanks.
Hello Wenjun,
Yes, you can import geometry from Flux 2D to 3D.
In standard context, Goto Project<Import<Import FLUX object. Select the Flux 2D model from which you would like to import the geometry.
Then, you can extrude in Z direction to get volumes.
Note : Before importing the geometry, delete the infinite box in the 2D model and then import the geometry in 3D.
Thank you,
Lavanya
Hello Wenjun,
Thank you,
Lavanya
