🎉Community Raffle - Win $25
Join and Win
Need Help Removing "-" character from names, but not from numbers in a combined string
User: "Aaron_21459"
Altair Community Member
Updated by Aaron_21459
Hello All
I am having difficulty trying to separate "-" from names while leaving it in for negative numbers.
The original file is a PDF which I can not get in any other format.
Occasionally a name is followed by a number with no space between them. I can split them to separate the name from the number until I run into a name that has a hyphen or a negative number.
Examples of data after I trap the Name and Reg Pay line as one trap to split later:
Header 1Header 2Header 3
Original stringNameNumber
Jane Doe 425.36Jane Doe425.36
Jane Smith-Doe 325.00Jane Smith-Doe- 325.00
Jane DoeDoe -170.15Jane Doe-170.15
Jane Smith-Doe852.15Jane Smith-Doe-852.15
As you can see, the top and middle rows works out fine, but the second and last row give me false negative numbers.
Original Data PDF Structure:
EENum     Name
Loc           JobCode                                   Reg Pay               Overtime
Department          1234               Accounting
1234567     Jane Doe                                   425.36               12.25
99999         RP1234
1234568     Jane Smith-Doe                         325.00                0.00
99999         RP1234
1234569     Jane DoeDoe                              -170.15              10.52
99999         RP1234
1234570     Jane Smith-Doe852.15                                          5.25
It is rows like that last one that are throwing me doing a normal capture.
Any suggestions would be appreciated. Especially ones that let me trap the last row and split the Reg Pay out automatically.
I am using version 13.4 of Monarch
Thank you
Aaron
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    hi A MAN,
    Have you tinkered with PDF Options before loading the PDF?  The PDF Options like stretch, monospace helps aligning columns and changing spacing for easier templating.
    For your PDF, if you can just add a space before name and number then it would be easier to split those two using RSplit function or other string functions.
    HTH
    Mela
    Altair Employee
    Accepted Answer
    Hi Aaron,
    I'm away from my PC today, so can't work out the exact formula. But I think the following approach would work.
    First, use the Rsplit based on the - character.
    Strip all spaces.
    Then test the 2nd character using Isalpha.
    If it is, you know the - is in a name, so strip all non numeric characters.
    If it is not, then it should be the final result.
    I think the initial rsplit on - will give you an empty field if there is no -, so you may need to test that first using instr.
    This works in my mind! But I need to test it to be sure and come up with a calculated field.
    Regards,
    Steve.
    Get Outlook for iOS<https://aka.ms/o0ukef>
    Altair Employee
    Hi Aaron,
    Strip all spaces.
    Regards,
    Steve.
    Hello Steve
    I’ll give you suggestions a try and see if I can get the results I need.
    <Steve I was able to use Lsplit/Rsplit and then an If statement to get what I needed.
    Thanks for the suggestions.
    Thank you
    Aaron
    Altair Employee
    hi A MAN,
    HTH
    Mela
    Hello Mela
    Yes, I did try the different options for PDFs. It looks like the original data merges some of the Reg Pay data when the names are too long to fit in the name column. I actual had to stretch the PDF to be able to get most of the data.
    Thanks for taking a look.
    Aaron
