Query on PBUSHT defined with KN line having non-linear force vs displacement graph
Hi,
I took a single spring element defined with CBUSH and assigned it a non-linear force vs displacement graph. When I apply one of the force values to it and check for displacement in spring, I am not able to correlate it with force vs displacement data given as input.
Please check.
File is attached here for further reference.
Thank you
