🎉Community Raffle - Win $25
Join and Win
How to judge a surface is curve surface or flat surface?
Hi,
I am the rookie of the tcl.I have some basic questions.But i can not find it in api document.
Supposed i have a solid,which has many surfaces and lines.
how to judge a surface is curve surface or flat surface?
how to judge a line is curve line or flat line?
For more,can i know the expression(formula) of surface(line)?
Thanks!
1 - 2 of 21
    ImotoUser: "Imoto"
    Altair Employee
    Updated by Imoto
    Hi @xiaoming
    Check the following things.
    ・line length vs point-point distance of each edges.
    ・normal of surface at each points.
    Related APIs.
    ・hm_linelength
    ・hm_getdistance
    ・hm_getsurfacenormal
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    There is an api but i can't remember, maybe it is removed in new version
    A workaround:
    A straight line is simply tested by
    proc IsStraight LineID {
        *createmark lines 1 $LineID
        catch {hm_getbestcirclecenter lines 1 1}
    A surface?
    - create a few lines on it (extract parametric lines)
    - check straight for those lines, if all straight => flat surf (not sure) :rolleyes:/emoticons/default_rolleyes.gif' title=':rolleyes:' />
