Geometry Cleanup
Hi,
I was practicing geometry cleanup on one of the tutorial models (clip_repair.hm) for tutorial HM-2000. I successfully cleaned up most of the free edges except for one.It is a free edge that forms a closed loop (missing surface).
I used Geometry > Create > Surfaces > Spline/Filler, but it doesn't work.
Any ideas on why it doesnt work?
Thanks,
1 - 3 of
31
Hello,
try to switch off 'keep tangency', in the most cases it helps and the result is still good enough.
Best regards,
Mario
