How to apply pressure and displacment outside of the surface in LsDyna PrePost?
Hi, I am working with LsDyna software. I need to apply: 1. pressure 2. displacement outside of solid part, on all of the surfaces in all directions? What is the best way to do this? So far I saw that most people determine curve of load t=f(F) (I'll probably use it for applying pressure outside of my part), but I still don't know how to apply displacement. I am appreciate for any help
Hi Premanand, this is exactly what I need. However, I can not find this option (pscrbdsp_N) in LsDyna PrePost. I think You use other software...? I am not sure.
This option is in HyperWorks, Ls-dyna user profile.
If you are using LS-dyna Tool, then you need to check with LS-dyna support. Here, we solve only HyperWorks related issues.
Thank you
Hi anna_p,
If i'm not wrong, you mean how to apply imposed/enforced displacement to the surface. Right?
So, you can go to analysis page > Constraints > Change the load type to PSCRBDSP_N > select the nodes > tick the direction in which you want the displacement and enter the value (i.e. how much displacement you want to impose).
For example to impose 100 units of displacement in x direction follow below image.
Thank you
