OSSmooth not working
Hi,
I created a lattice optimized structure, and I would like to export it to an *.stl file, but first I would need to run OSSmooth on it.
When I try to do so, HyperMesh says:
'Invalid input file command. Please check logfile'
I checked the logfile, where I found:
'Warning: failed to detect topology optimization result, turn off isosurface
Error: OSSmooth fail to detect optimization result. Abort.'
I turned off isosurface, but there is another error:
'Invalid parameters string'
No matter what I change in the settings of OSSmooth panel, I can't make it work.
I attach the files as *txt, rename it to *.rar
Thank you
Zsombi
1 - 1 of
11
there is no way to export a lattice optimized structure for now. Our developers are working on it and I hope some feature to export lattice strcuture to .stl will be available for 3D printing
/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
