How to import the mesh file and visualize the temperature results in HyperView?
I have temperature nodal results Abaqus input file.
I have a model mesh Abaqus input file as well.
Like this,
Temperature.inp (contains nodal temperature values - Nodes corresponding to the Model.inp mesh file)
Model.inp (Contains the mesh details)
Or is there some file format that needs to be changed?
Thanks.
1 - 1 of
11
Hello,
You can import the model (mesh file) independently. Or some results files contain the mesh as well.
https://help.altair.com/hwdesktop/hwx/topics/panels/load_model_panel_r.htm
Verify you have the correct output request for the results you want to visualize from the solver. You can then contour the results.
https://help.altair.com/hwdesktop/hwx/topics/panels/contour_panel_r.htm
