Error Creating New Process
User: "Paulo Araujo"
Altair Community Member
Updated by Paulo Araujo
Hi friends.
I'm having problems to run a same simulation already done in 2019.1 on version 2019.3.
See the pictures. Please can anyone advise asap.
Thanks in advance.
Best regards,
1 - 6 of 61
    OP
    Please anyone can give a reply?
    Should I install version 2019.1 a run this simulation? Any problem with 2019.3?
    regards
    User: "SouravDas0306"
    Altair Employee
    Updated by SouravDas0306
    Hi Paulo,
    I was able to do the simulation in 2019.3, I guess this is the Alavanca Stilo file_13 ( regarding HPDC ),( Kindly correct me if I am wrong) I am sharing the file with you :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    Desculpe pela resposta tardia, pois estou em viagem.
    OP
    Thank you Sourav. Yes HPDC process. What do you think was the problem for me be ale to run the simulation. Not Enough memory??
    Altair Employee
    Hi Paulo,
    I dont think so that's the problem your space in your system is more than sufficient to run this model. When something comes like this next time, just restart the software and reassign the boundary conditions  for your model.
    OP
    Thank you very much for your reply Sourav. I did runned the new simulation. It was exavtly the problem, I restored the defalut setting for locations for calculations and worked normally. I did made some changes on this trying to find the problem.
    Once more, thank you for your attention. Regards.
    Altair Employee
    No Problem Paul, lets us know if you face any problem in future will be happy to help you. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
