🎉Community Raffle - Win $25
Join and Win
area,inertia and torsion values of cbar element
User: "brahmadev"
Altair Community Member
Updated by brahmadev
How to get the area, inertia and torsion properties of cbar elements using the tcl/tk script.
1 - 5 of 51
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hello @brahmadev
    It's up to which UserProfile are you using...
    If you are using OptiStruct profile, you can get the data with follwoing commands.
    AREA :              hm_getvalue elems id=1 dataname=property.BeamSecA.results_area;
    Inertia 1a :       hm_getvalue elems id=1 dataname=property.BeamSecA.results_Icentroid1;
    Inertia 2a :       hm_getvalue elems id=1 dataname=property.BeamSecA.results_Icentroid0;
    Inertia 12a :     hm_getvalue elems id=1 dataname=property.BeamSecA.results_Icentroid2;
    Torsion :          hm_getvalue elems id=1 dataname=property.BeamSecA.results_J;
    Note: id= have to chage to your actual model's element ID.
    Thanks,
    Imoto
    User: "brahmadev"
    OP
    hello imoto san
    I am using nastran user profile.how would the syntax differs in that profile.
    thanks
    brahmadev
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hello @brahmadev
    Fortunately OptiStruct and Nastran profile almost same:-)
    I guess you can get the data with last posted commands.
    Thanks,
    Imoto
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hello @brahmadev
    Sorry I found my misstake, you are asking about CBAR, but I was consider about CBEAM.
    For the CBAR, the attribute name is little bit changed.
    Following commands should be works fine for CBAR on OptiStruct and Nastran profiles.
    AREA :                 hm_getvalue elems id=1 dataname=property.BeamSec.results_area;
     Inertia 1a :         hm_getvalue elems id=1 dataname=property.BeamSec.results_Icentroid1;
     Inertia 2a :         hm_getvalue elems id=1 dataname=property.BeamSec.results_Icentroid0;
     Inertia 12a :       hm_getvalue elems id=1 dataname=property.BeamSec.results_Icentroid2;
     Torsion :            hm_getvalue elems id=1 dataname=property.BeamSec.results_J;
    Thanks,
    Imoto
    User: "brahmadev"
    OP
    Thank you imoto san
    Above commands are working to find area,inertia and torsion
