🎉Community Raffle - Win $25
Join and Win
Difficulty acquiring good quality mesh
Hello,
I've encountered quite a lot of difficulty in meshing the below provided part (STEP file).  It's a bearing house, a bearing fits into this part, and then the part is bolted onto the base of our robot.
I've tried deleting the elements near the holes then using Morphing, projecting nodes onto the hole surface and then filling the gap with pyramid/tetra elements wherever i can, but the final mesh doesn't look right at all as you can see in the picture provided.
Regards,
Vinamra
1 - 6 of 61
