🎉Community Raffle - Win $25
Join and Win
Non Zero Length CBUSH elements selection based on their CIDs
User: "sanket_patil"
Altair Community Member
Updated by sanket_patil
Hello All,
I want to select the non zero length CBUSH elements according to their CIDs, i.e. elements having local coordinate system, global coordinate system and no coordinate system. I tried with my code, but it is giving global coordinate system value (0) if the CID field is empty. Which command should i try?
As shown in above snap, CID field is empty. but it is giving value 0.
Please help me on this.
Regards,
Sanket
1 - 2 of 21
    User: "JulienCOMAS"
    Altair Employee
    Updated by JulienCOMAS
    Hello,
    you can try to query the status of the attribute CBCID with this command :
    hm_attributestatus elem $element_id CBCID -byid
    if the command retruns 1, CBCID is used, if the command returns 0 then the CBCID is not defined.
    can you try and let me know?
    thanks and Regards
    Julien
    OP
    Hello,
    thanks and Regards
    Julien
    Thank you so much !
    Regards,
    Sanket
