🎉Community Raffle - Win $25
Join and Win
Flow over a triangular cylinder in 2D
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I a trying to simulate the flow over a triangular cylinder in 2D. When I try to export the .inp file in AcuSolve, I get the following error
'There are no volume elements displayed'.
If I click on continue, I receive the following message
'Only Acusolve surface mesh file (*.arm) will be exported'.
Could you please tell me what can be the problem here?
PFA the model.
1 - 2 of 21
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi ujjwalmohanty
    Can you please re-check the version of your file and resent it with a compatible version.
    Thanks
    User: "Pranav Hari"
    Hi ujjwalmohanty
    I received your file. It seems like there are no solid elements created in your model. Can you create solid elements and try exporting.
    Thanks
