Altair RISE
Nominate Yourself Now!
Creating a material database
User: "Viking_d"
Altair Community Member
Updated by Viking_d
Hello all,
How do I create a material database using a text editor such as Notepad or Jedit, so that I can include it in the Master model as an Include file. I need to create  a card for RADIOSS. Is there any documentation or videos that I can watch?
Thanks in advance for your answer.
1 - 15 of 151
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hello all,
    Could someone please tell me how to do the above?
    Thank you
    User: "karthikeyan Thangavelu_22227"
    Updated by karthikeyan Thangavelu_22227
    Hi,
    If your aim is to create a separate  include for the material model , we can create it in Hypermesh itself. No need of using text pad.
    Regards,
    Karthikeyan
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi vishruthdilip
    Have a look at the online help documentation.
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hello @Pranav Hari
    I have an Abaqus material card. I need to convert this to a RADIOSS card. How do i do it?
    User: "Pranav Hari"
    Hi vishruthdilip
    Try this
    Also, have a look at the solver interface documents from help
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hi @Pranav Hari
    I want to know how to work with text files. For instance, I have come across a .k file which contains the material database, which I inlcude in the master model for LS-dyna solver. And similarly a .bdf file for the optistruct solver. How do I create one for RADIOSS, without using the GUI?
    Thanks
    User: "Pranav Hari"
    Hi vishruthdilip
    .K file and .bdf files are input files of other solvers. Similarly, you have .rad file for Radioss which is a ASCII file. You can as well edit this file in the text pad or so and make changes accordingly. In your case, if you need to edit some material data, you should first have a reference .rad file (0000.rad) which is a starter out file. You can make changes to this starter out file.
    Also have a look at the radioss files from the e-book https://altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/ (page 35, Radioss files)
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hi @Pranav Hari,
    So the simplest way of say creating a MAT/LAW2 would be to copy the Example, as shown in the picture below in the text editor ( .rad file )  and edit the parameters as required? Am i right?
    User: "Pranav Hari"
    Hi vishruthdilip
    Yes it is the easiest way
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hi @Pranav Hari,
    For radioss to be able to read the include file, what should I save the file as? What should the file extension be?
    Hi ,
    The extension will be .rad as shown in the image below
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hi @Pranav Hari @karthikeyan Thangavelu,
    I have created the include file. But when i import the solver deck, it shows the following error.
    Warning:  starter Input Deck contains Keyword   which is CURRENTLY UNSUPPORTED in HM present at line number 27
    Summary:Feinput finished with 0 errors and 1 warnings.
    My input deck has only 26 lines.
    I've also tried it with a more complex file which I could run before, but it shows the same error.
    User: "Pranav Hari"
    Hi vishruthdilip
    Can you please share us the Radioss starter and include file.
    You can use the secure link if needed.
    https://ftin.india.altair.com:8443/filedrop/~Ma3TaE
    User: "Viking_d"
    OP
    Updated by Viking_d
    Hi @Pranav Hari
    I have shared two example files. Could you please check it and let me know?
    User: "Pranav Hari"
    Hi vishruthdilip
    I tried opening the files. It worked fine at my end. However, the error message appears. Try deleting the card which is marked on the image, export it as .rad file and import the new file again. This should import without any error message
