I have project with CST Studio Suite but I would like to import this antenna to CADFEKO. I have CADFEKO ver 2018_edu and i can't do this. I tried with formats .sat ; .nas , .stl. What i have to do?
The student edition of FEKO does not support geometry import or export - see https://altairuniversity.com/feko-student-edition/. You can import and export Parasolid, since that is the native format used in FEKO. If you can export a Parasolid file, you will be able to import it into FEKO.
Hello Pawel,
