Hi all,
Is there any way to model bolts apart from rigid to measure forces on bolt?
Could you please share a model or video ?
Thanks
Hello,
You can create bolts using 1D>>connectors>>bolt
Please watch this video for reference.
https://www.youtube.com/watch?v=zwNIfNfaPWg
You can measure the forces on the bolt using this method.
Thankyou
Hi Sanjay,
When i apply this model as bolt, there will not take place different results between usage of hole and usage of slot.
I want to find out differencies between usage of hole and usage of slot.
Is there any video or solution for this issue ?
Can you please share some pictures of your issue and please elaborate on your problem.
Hello,
Thankyou
