Flux 2D
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
hi everybody, please I have a 2D flux simulation problem I have powered my permanent magnet synchronous machine with a three phase voltage source one with a good voltage phase shift. according to the results I got a torque with more than the nominal torque and the currents are very high values.
ecause someone can help me thank you????
Welcome!
Answers
  • asoualmi
    asoualmi
    Altair Employee
    edited September 2020
    Hi,
    In the case when you sue a voltage source you need to use several periods (more then 5 periods). The reason that you get a Hight value of the current is du to the fact that you are in transient regime and not in steady state. To reach the steady state region you need to increase the number of period that you use in the solving scenario.
    Best regards.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi abdessamed
    I supplied the machine with voltage with an effective value 220
    the nominal current  In=130 A
    the torque nominal Cn=2100 N.m
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.dd8e5e65a57e68bcc9ebc4e292c74d5a.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.fcf1a85b84fa5fb6580d81972c68611c.png
  • asoualmi
    asoualmi
    Altair Employee
    Hi,
    Did you use the right frequency?
    Can you share your Flux Project.
    Thanks.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    hi,for frequency it's 50 Hz
    please can you give me your email to send you the Flux Project
  • asoualmi
    asoualmi
    Altair Employee
    Hi,
    Can you delete the results and use zip format to send me the project.
    Best regards.
Welcome!
Welcome!
