🎉Community Raffle - Win $25
Join and Win
How to mesh a sphere as a solid?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello persons,
I need to simulate a ball colliding with a plan. For this I need mesh the ball as solid.Could someone tell me how to do this?
Thanks
1 - 14 of 141
    Altair Employee
    OP
    Hi frogmam
    You can try trimming the sphere into quarter spheres and make it mappable and carry meshing.
    Altair Employee
    OP
    @frogmam: Here is my example how to make hexa mesh for a sphere:
    https://www.dropbox.com/s/aqu17mgeaxogj63/sphere.hm?dl=0
    See also screenshot.
    HTH,
    <?xml version="1.0" encoding="UTF-8"?>post-889-0-22666200-1416470219_thumb.png
    Altair Employee
    OP
    Very Thanks!
    Prakash Pagadala: I getting his advice.
    Q.NGUYEN-DAI: I liked this mesh you have a tutorial to make it?
    HTH,
    Hi frogmam
    Altair Employee
    OP
    Very Thanks!
    Load my HM model and you straightaway understand how to do that image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hii
    This is my procedure
    1. make a sphere
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-31519800-1417152141_thumb.pn
    2. make a quad
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-70892400-1417152154_thumb.pn
    3. cut the quad
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-31581800-1417152170_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-90792500-1417152182_thumb.pn
    4. rotate the quads
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-28799100-1417152192_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-85813900-1417152202_thumb.pn
    5. make a temp node
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-61507600-1417152213_thumb.pn
    6. make a hexa
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-95120600-1417152231_thumb.pn
    7. project a temp node on sphere
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-98685100-1417152245_thumb.pn
    8. make 3 hexas
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-08568500-1417152249_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-51789800-1417152365_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-95415900-1417152370_thumb.pn
    9. equivalence
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-64304500-1417152374_thumb.pn
    10. delete all quads (delete elems>by config>quad)
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-71458000-1417152379_thumb.pn
    11. split hexas
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-99560100-1417152385_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-08841200-1417152398_thumb.pn
    12. project outer nodes on sphere (select 3 nodes > by face)
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-60448000-1417152404_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-17341800-1417152412_thumb.pn
    13. reflect hexas to form a sphere
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-88970000-1417152417_thumb.pn
    14. equivalence
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-32186400-1417152430_thumb.pn
    15. smooth hexas
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-10821100-1417152467_thumb.pn
    image/emoticons/default_cool.png' alt='B)'>
    finished:
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-34113200-1417152470_thumb.pn
    Altair Employee
    OP
    @tinh: my method is different, no project at all. Your result of step 12 is not so good, at border of sphere.
    User: "tinh"
    Updated by tinh
    Yes, so at step 15 i smooth the hexa and result {last image} looks not bad
    anyway I hope smooth operation for solid elems has options like for 2d elems (size, shape, angle,..)
    Altair Employee
    OP
    HTH,
    Hello,
    Would you please take snapshot of all steps you have done.
    Thanks,
    Altair Employee
    OP
    Hi frogmam
    i´ve try to open your own version of the meshing sphere but it isnt compatible with my 12.0 version can you please make some screenshot
    Thx
    Altair Employee
    OP
    Altair Employee
    OP
    Hey,
    thx for this file. I´ve already modeled something like that but my Prof want that the quad elements on the circle face are feiner as possible and the rest of elements doesnt matter because this will be the contact surface between sphere an plan we have to analyse. how could i realize it in hypermesh?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    How about spin option? See attached screenshot.
    Regards
    Rahul R
    Altair Employee
    OP
    Spin method is ok too. But you have to accept some PENTA elements :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "falkirk99"
    Altair Employee
    Updated by falkirk99
    Is there an easy way to share this with a colleague? I couldnt find permalink.
