🎉Community Raffle - Win $25
Join and Win
Run a tcl script in 2023
User: "Arno Heidkamp"
Altair Community Member
Updated by Arno Heidkamp
How to run a tcl-script in new HyperWorks 2023?
The help is misleading:
Run Scripts
I can find neither a "Run" in the File menu, nor a "Standard toolbar", nor a "Utility" menu.
Sad bad true ...
Kind regards,
Arno
1 - 4 of 41
    User: "Sriramanuj_16"
    Altair Employee
    Updated by Sriramanuj_16
    Hi Arno,
    Please find the options here in the attached image to run the .tcl scripts.
    Regards,
    Sriramanuj Prabhu.
    OP
    Hi Arno,
    Regards,
    Sriramanuj Prabhu.
    Many thanks, Sriramanuj Prabhu!
    Still, the manual should be updated.
    Kind regards,
    Arno
    Altair Employee
    Kind regards,
    Arno
    Hi Arno,
    We are currently in the process of updating, and it will be addressed shortly.
    Thank you so much ????.
    Regards,
    Sriramanuj Prabhu.
    User: "Paulo  Libório"
    New Altair Community Member
    Accepted Answer
    Updated by Paulo Libório
    Hi Arno,
    Regards,
    Sriramanuj Prabhu.
    Hey Arno,
    You can also drag and drop your .tcl file into the Tcl command window. To enable it, go to View Menu > Tcl Command Window
    Kind regards,
    Paulo Libório.
