🎉Community Raffle - Win $25
Join and Win
Suppress warning - point to curve (not exactly aligned)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear MotionView users,
*** Note: I've also posted this message in the 'MotionSolve' section of this forum. But I think this location is more suitable for the question. ***
I've constructed a model in which an object should follow a curve. This object is modeled in Solid Edge and the geometry is imported. Since the origin of the curve can slightly deviate, the body that should be in contact with the curve is not exactly aligned with the curve on the first sample.
Now I got the following warning from the solver:
WARNING: Marker I NOT coincide with curve in Body J!
          Minimum Distance = 6.610E+00
          Initial PT-CV U  = -9.766E-01
I would like to suppress this warning (or change the checking criteria) since I'm ignoring the warning if the initial offset is small.
Can someone help me suppressing this warning or changing the criteria for the check?
Kind regards,
Geert-Jan
1 - 2 of 21
    Altair Employee
    OP
    Hi Greet-Jan,
    I am afraid there is no command to suppress the warning message.
    could you please let us know what the use case is?
    Altair Employee
    OP
    Dear Prakash,
    Thanks for your answer. Too bad that there is no option to set the checking criteria in MotionView or in MotionSolve. I always prefer to have no warnings present, and if there are warnings I can accept, I would always like to suppress them.
    Kind regards,
    Geert-Jan
