Shell element
Hiii.
I wanted to use 8 noded shell element in my analysis...which element in hypermesh is 8 noded shell element?
See attached screenshot for Radioss shell element formulation.
That is for 4 node shell element...i want to use 8 node shell element.
please see the screenshot.<?xml version="1.0" encoding="UTF-8"?>
RADIOSS do not support 8/6-noded shell element.
Any specific reason for 8 noded shell.
What type of analysis you are trying at your end?
Just wanted to improve my simulation results as in many Literature I found they used 8 noded shell elements.
I am trying to simulate Incremental Sheet Forming process..I just wanted to improve simulation results..with help of 8noded shell elements.
Instead of working with 8-nodes shell, you can refine your mesh with 4-nodes shell.
CPU time will be increased, but you have better results (theorically!)
Use 2nd order shell elements if you are using OptiStruct
