Shear center or neutral axis
Hi everyone, I have some matters with 1D element.
In beam structure, connecting locations by welding include shape steels as channel and angle steel (nonsymmetrical section) . Absolutely, we shall model these steels into lines. Shall we create lines on shear center or neutral axis ? What case is suitable for behavior in real-life?
Thank you everyone
Best Regards.
1 - 4 of
41
Depend on your real structure: forces are transfered via welds, sum of these forces called total force and I think beam's node should be at position of the total force.
