Creating User Toolbars in HyperMesh
User: "tinh"
Altair Community Member
Updated by tinh
Hi B)
I made this package to help creating user toolbars:
It is useful for someone has many scripts and wants them to be available by one clicking on HM GUI
Please notice me if any bug occurs.
example:
Enter here to download:
 https://community.altair.com/community?id=community_blog&sys_id=0e6d8e3f1b64ac90c4dfdbd9dc4bcbd5
1 - 19 of 191
    User: "Brian DO_20786"
    Updated by Brian DO_20786
    GreatB)/emoticons/default_cool.png' title='B)' />
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Nice work. Will save a lot of time.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    @tinh: Is there any possibility to install into user's folder instead of HM Installation folder?
    When I click on 'Add Command bouton' there's error:
    HW 2017.2.1
    OS Linux CentOS 7 x64
    User: "tinh"
    OP
    Updated by tinh
    Yes, there is. But at least we need to add a package index file in hm home as an entry point for auto-start, or you have to add source $tboptsfile to hmcustom.tcl, or source it each time open hypermesh
    I will make an Installer that help to select user's folder to install tbopts, this is better than you have to make it your self
    User: "tinh"
    OP
    Updated by tinh
    About linux OS, I will check environment folder and update the error soon.
    User: "tinh"
    OP
    Updated by tinh
    I updated it with an installer.tcl file. Just copy folder tbopts to your own location, open hypermesh and File>Run>Tcl/Tk Scripts to run Installer.tcl
    folder .../hm/script need to be writable, because pkgIndex will be copied there
    User: "vipin_22401"
    Updated by vipin_22401
    Hi tinh,
    Could you please tell me how to encrypt the .tcl file as you did?
    Is there any free software available for encrypting?
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hello Tinh,
    I'm not able to access this file.
    User: "tinh"
    OP
    Updated by tinh
    Altair Employee
    Hello Tinh,
    I tried to use your script in my work enviroment, where I'm using multiple hmcustom files. I don't want (and cannot) modify most of them.
    I would like to modify only the certain one. The one I've created and added (by appending the enviromental variable) myself.
    I have managed to add 'tbopt' script in this file manually (basing on your instalation scripts). Now i would like to make your script to modify only the certain hmcustom file in the process of adding toolbars and buttons. Can you show me the way?
    Regards,
    Michal
    User: "tinh"
    OP
    Updated by tinh
    Hi
    Tbopts.tcl does not modify hmcustom.tcl
    Just installer.tcl does
    User: "Rakesh_kumar"
    Updated by Rakesh_kumar
    Hi Mr. Tinh
    The got the following error message while running add toolbar script.
    tag name 'Undo-Redo' # must be alphanum should not contain any wildcharacters
        while executing
    '::hwtk::istagvalid $tag'
        (object '::.tbopts.f1.lb' method '::hwtk::widget::HWListbox::add' body line 7)
        invoked from within
    '# Compiled -- no source code available
    error 'called a copy of a compiled script''
        (procedure 'p_mnuOptions_Invoke' line 1)
        invoked from within
        (in namespace inscope '::tbopts' script line 1)
        invoked from within
    '::namespace inscope ::tbopts p_mnuOptions_Invoke'
        (menu invoke)
    Hm version 2019.1
    Thanks in advance
    User: "tinh"
    OP
    Updated by tinh
    Sorry, could you test it on hm2017?
    I don't have v2019 so i need to confirm the bug comes from new version or something else
    User: "JiWon Seo_20453"
    Altair Employee
    Updated by JiWon Seo_20453
    Hello! I want to download your script!
    But I can not find... Could you share the script?
    Thanks in advance.
    Jiwon Seo
    User: "tinh"
    OP
    Updated by tinh
    Thanks in advance.
    Jiwon Seo
    Hi Jiwon,
    This is yours:
    Altair Employee
    can you download tbopts.zip here?
    https://forum.altairhyperworks.com/index.php?/topic/16835-update-hypermesh-extensions/&tab=comments#comment-30266
    I want to use your script! but I can not download in anywhere..
    Could you share it?
    Best Regards,
    Jiwon Seo
    User: "Brian DO_21608"
    Updated by Brian DO_21608
    How about 2021.2 version ?
    User: "Adeline War_20893"
    Updated by Adeline War_20893
    Hello, @tinh May I please get your email id so I can contact you directly for any query?
    Also, I would like to know if there are control cards to call a .txt file for contact deformation/contact sliding distance and stress?
    Thank you,
    Adeline
