🎉Community Raffle - Win $25
Join and Win
My component is removed in results file
User: "Fasahat RIzwi"
Altair Community Member
Updated by Fasahat RIzwi
Hi,
So I'm pretty new with this Hypermesh software and I'm having this issue with the model I'm analyzing.
I'm looking at a Linear static analysis of a  car jack model, where I've applied a force to the top of the model, and then a fixed support to the bottom of the model (shown below).
My issue is when I analyze the results, the component with the applied force gets removed from the results.
My thinking is that I'm doing something wrong with the connectors/contacts. Since it's likely the force is being applied and is "pushing" the component out of the system, rather than applying the force and then deforming the entire structure. I tried to use the connectors feature to fix this, but I still have the same problem.
I've attached my model and output file, if anyone could potentially offer some guidance/help? I understand I'm probably making quite a few errors, but I'm still learning how to use this software.
Thank you
