Section cut in HyperMesh for check elements
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello everyone
I have a quite complexe geometry to mesh. For this I have applied 'Check Elements Quality Index', where it shows the quality of the elements. Now I would like to know, if there is a possibility to cut the model, to be able to see the inner contours and how the elements looks there. Then I could have a better overview of the situation and know what to change for the mesh.
I thank you in advance for your help!
Welcome!
Answers
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    edited March 2018
    Hello,
    Align the model view to an axis first.
    Then click F5
    This is the mask element panel.
    Select the elements how ever you want (preferably using a rectangular section)
    Then click on mask elements.
    This should solve your purpose.
    Thankyou
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Hi,
    Along with the option specified by Sanjay you can also try the hidden line option (Post>>hidden line) in HyperMesh, where you can trim the model with respect to planes.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited March 2018
    Great thank you very much!
    Is there also a way to cut it with the coloured element quality check?
    edited March 2018
    Mask the elements first using the F5 panel.
    Then create a View of this by right click>>View
    Then you can go to Quality Index Panel.
    Thankyou
Welcome!
Welcome!
