Importing Solidworks Parts Into Inspire.
I am trying to trial the software and have a number of models I want to look at testing the software on.
My only problem is I cannot seem to import SolidWorks parts into Inspire, nor export in a format that works either...
Is there something I am doing wrong.
Inspire:
OPEN -> PART.SLDPRT.
OPEN -> PART.EVO
SolidWorks:
SAVE AS 'EVOLVE MODEL.EVO'
Thanks in hope
James
I'm struggling with this issue as well.
I have v9.5 Inspire, and want to open a SW assy with the design region, and support and force regions, as separate parts.
No matter if I open, or import, the assembly, or any single .sldprt file, absolutely nothing appears on screen. The item does appear on the left menu, but selecting it does nothing.
Opening a step file of the same parts sort of works, but it shouldn't be necessary.
Any idea what's going wrong?
Is it an issue with SW 2014 compatibility?
Very frustrating.
Thanks again, but I have just realized that my version is in fact 2013, or more specifically 2013-2014 education edition.
Any idea why I can not use any .SLDPRT or .SLDASM files?
It seems to open, and the name appears on the left column, but nothing is in the main window.
Any help is appreciated.
Stephen
To go from SolidWorks to Inspire your best option would be .X_T.
The .evo file format is for Evolve.
Let us know if you are still having trouble opening the files in Inspire.
Thanks,
