A Chinese student is asking for help!
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi experts :
I am a student from China.  I do a research of bus body frame, and I have finished the midsurface and repaired  the model. Now I want to simulated welding by using common nodes. but I don't know how to repair the gap between the Square tubes(like the picture). The attachment is my model.
So I sincerely hope to guide me in completing the grid of this model. Thanks in advance!<?xml version="1.0" encoding="UTF-8"?>1.thumb.png.86f9b4f523cc23270ee57646f46ba353.png
1 - 15 of 151
    Altair Employee
    OP
    Hi Liusst,
    Please go through this video. I think it will solve your problem.
    Thank you
    Altair Employee
    OP
    Hi Liusst,
    sorry, I try to do it, but it don't work. Maybe I think it's that the gap between the tubes is created after midsurface. Before midsurface, there are not the gap in my model.Can you have another solution?:D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    Thank you
    Altair Employee
    OP
    Yes i know that the gap was created after creating mid-surface. And this is the way to connect it. Or try Extend option in the Surface edit panel.
    Thank you
    Altair Employee
    OP
    Thank you for your reply again!
    I have repaired the gap by surface/trim with line and replace lines (like the picture 1), and create the grids like picture 2, is that grids right??
    Altair Employee
    OP
    Please can you share the model file.
    Please use below FT link to share your model.
    https://ftin.india.altair.com:8443/filedrop/~osKE8Q
    Thank you
    Altair Employee
    OP
    sorry I don't know how to use FT link. My model in these attachment.
    Altair Employee
    OP
    Hi Liusst,
    You have done repaired it correctly. You can use Node edit to align the elements to the Node indicated in black circle.
    Thank you
    Altair Employee
    OP
    Hi Liusst,
    <?xml version="1.0" encoding="UTF-8"?>image.png.af2de8237a2b8509996f699744e87f83.png
    Thank you
    Thank you for your reply!
    Yes, It can solve the problems by align nodes. But as you can see, there are lots of nodes need to align:ph34r:/emoticons/default_ph34r.png' srcset='/emoticons/ph34r@2x.png 2x' title=':ph34r:' width='20' />:(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />:(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />,Is there any skill that can be done quickly?
    Altair Employee
    OP
    Hi
    Please can you share me the latest model. I just want to check why the elements are not aligned on the surface.
    Thank you
    Altair Employee
    OP
    Hi Liusst,
    Please, try Translate or Project option in the Tools page. Using these options you can align multiple nodes on the surface in one go.
    Thank you
    Altair Employee
    OP
    Hi
    Thank you
    Hi
    The attachment is what I just finished, the 0710 is my model. and this is my way:
    step1: surface edit/trim with lines
    step2: edge edit/replace or quick edit/replace point
    Or You can do it in your own way , and tell me how to do that.
    Thank you~
    Altair Employee
    OP
    Hi Liusst,
    Thank you
    Hi Premanand Suryavanshi
    I have completed the repair of the model(the 0711-zhong), Can you check it for me? or you can create the grids to this model, and  check it right or not.
    Thank you very much!
    Altair Employee
    OP
    Hi Liusst,
    Sorry for late reply.
    I see that your CAD model is not good. Please zoom into the regions shown in the below image and look at it, the surfaces/lines are going beyond the other surfaces/lines. The geometry is not created properly. This is the reason you are facing these problems. Please create a proper CAD and try again.
    Thank you
    Altair Employee
    OP
    It is very kind of you to help me. I rebuilt a simple model according to your suggestion, and finished the grids(showed in 0712-2.hm). It seems to be correct this time.
    By the way, Is there any skills to improve the mesh of the triangle area?
    Thank you!
    Altair Employee
    OP
    54 minutes ago, Liusst said:
    Hi 0712-2.hm). It seems to be correct this time.
    Thank you!
    Mesh looks fine. But, if you still want to make it better, try Edit Element option.
    Thank you
