i don't have a direct command for that, but running the command you've mentioned, you could use multiple config codes.
For 2D, i.e:
*createmark elems 1 "by config" 103 104 105 ...
For 3D, i.e:
*createmark elems 1 "by config" 203 204 205 206 207 208 ...
Each of these codes represent a certain element type, extracted from the documentation, under 'Data Names'.
Thanks Documentation is so unreadable for me
Can you hint to me on how to get node coordinate, I found the command
hm_getentityvalue
but I can find no explanation of it in the documentation. Could you help me?
Any hints how to learn hm scripting? There are not many resources.
For 2D, i.e:
For 3D, i.e:
For 2D, i.e:
For 3D, i.e:
