Hello, I am learning to use the altair monarch program and I did not understand what kind of content it uses..for example, if he wants only tables, whether in pdf or web format, this is only?
Monarch has the ability to read/obtain data from the following sources you may see below. It is not limited to PDF or Web format. It can read Text and other data sources as long as you have credentials to connect/read from the other various DB sources.:
Hello @Asma'a Alndhari,
Monarch Help Guide- Data Sources
Quick Video to Access Data
Group
Data Source
Favorites
Displays all data sources you pin as favorites.
Refer to Working with Data Source Favorites below.
Monarch File
Monarch Model
Monarch Project
Monarch Workspace
PDF & Text
Delimited Text
PDF Report
PDF Table Extractor
Text Report
Spreadsheet
Excel Worksheet Design
Google Sheets
Microsoft Excel
SAS Transport File Format (XPORT) Version 5
Database
DB2
Informix
Microsoft Access
My SQL
ODBC
OLEDB
Oracle
PostgreSQL
Snowflake
SQL Azure
SQL Server
Sybase IQ
Teradata
Vertica
Active Directory
Altair Monarch Server Library
Amazon S3
Azure Data Lake Storage Gen2
Box Cloud Storage
Business Objects
Google Ads
Google Analytics
Google Drive
Hubspot
JIRA
NetSuite
Salesforce
ServiceNow
SharePoint
Splunk
SugarCRM
Zendesk
Big Data
Amazon EMR Hive
Amazon Redshift
Cassandra
Cloudera CDH Hive
Cloudera Impala
Google BigQuery
Hadoop Hive
Hortonworks Hive
IBM Cloudant
MapR Hive
MongoDB
Spark SQL
Web
HTML
JSON
ODATA
XML
All
Displays all data sources in alphabetical order.
