🎉Community Raffle - Win $25
Join and Win
How to model belt/pulley system with 2 belts?
User: "Brian_20847"
Altair Community Member
Updated by Brian_20847
Hi everyone,
How to model a belt/pulley system with 2 belts? How to model belt tension in this system?
1 - 2 of 21
    User: "Praful"
    Altair Employee
    Updated by Praful
    Hello Brian -
    Create a reference marker in the plane of the belt pulley system such that the pulleys lie on the X,Z plane.
    Create the belt pulley system using the marker as Reference marker and the X and Z coordinates for the pulley based on the reference marker frame.
    Repeat the above steps for the 2nd pulley, but the marker is at the plane of the 2nd pulley.
    You may fix the pulleys with a fixed joint separately.
    Note that this method works for the the Discritized rigid bodies belt. It may not work for NLFE belt unless the plane of marker matches with the Global Frame orientation. That's a general limitation of NLFE belt system and nothing to do with multiple belt-pulleys.
    hope this helps.
    Praful
    User: "Brian_20847"
    OP
    Hello Brian -
    hope this helps.
    Praful
    Hi @Praful Prabhu,
    Thanks for your answer.
    We have many types of belts (ladder belt, flat belt...). How to model each type?
    Thanks
