How to create track vehicle modeling in MV 2023?
Hi experts,
I watched the video in Altair How to.
- I want to ask how to know link length, link thickness, and link width based on the geometry (using CAD graphics).When I tried this, it had this error as the image below:
- I have another question. how to modify the point to match the teeth geometry in the sprocket:
Please find the attachment to know my model.
Thanks
1 - 6 of
61
I tried to use a repositioned link graphic but it doesn't show the graphic.
When I use primitive graphics, no errors appear.
please find the attach to know link CAD
Thanks
Hi.
Your "link.x_t" needs to be scaled into mm. It was x1000 to small. Then it wokrs.
I have attached a re-scaled version of the link.
/Erik
Why does the track not match with the wheel and idler?
Thanks
Hi Brian,
Your “link-graphic-file” is not centered on (0,0,0) which then results in an offset to the wrapped link positions. Using the std. primitive CAD for the links shows good correlation.
Reposition the link-CAD to be centered at (0,0,0) then it should align.
/Erik
