🎉Community Raffle - Win $25
Join and Win
How to import plot style in hyperview using Tcl Command
User: "sanket_patil"
Altair Community Member
Updated by sanket_patil
Hello All,
Can anyone suggest me the tcl command to import plot styles in hyperview?
Thanks in advance.
Regards,
Sanket Patil
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Please take a look at the RestorePlotStyle API, under the Contour Control Class.
    Probably you're looking for this:
    poIContourCtrl RestorePlotStyle
    Resets the contour controller settings with a memorized plot style.
    poIContourCtrl_handle RestorePlotStyle style_name
    HyperView Tcl Modify
    This command updates the contour controller settings with the new settings specified by the plot style name.
    style_name
    The name of the plot style.
    To restore a contour plot style:
    hwi OpenStack hwi GetSessionHandle session_handle session_handle GetProjectHandle project_handle project_handle GetPageHandle page_handle [project_handle GetActivePage] page_handle GetWindowHandle window_handle [page_handle GetActiveWindow] window_handle GetClientHandle client_handle client_handle GetModelHandle model_handle [client_handle GetActiveModel] model_handle GetResultCtrlHandle result_handle result_handle GetContourCtrlHandle contour_handle contour_handle RestorePlotStyle style_name hwi CloseStack
    OP
    style_name
    Hello @Adriano A. Koga,
    Thanks for guiding me.
    I have one piece of code as below,
    hwi OpenStack
    set t [::post::GetT];
    hwi GetSessionHandle sessh$t
    sessh$t GetProjectHandle ph$t
    ph$t GetPageHandle pgh$t [ ph$t GetActivePage]
    pgh$t GetWindowHandle wh$t [pgh$t GetActiveWindow]
    wh$t GetClientHandle ch$t
    ch$t GetModelHandle modH$t [ch$t GetActiveModel]
    modH$t GetResultCtrlHandle anim$t
    anim$t GetContourCtrlHandle result$t
    result$t GetCurrentPlotStyle
    set psList [result$t GetPlotStyleList]
    result$t RestorePlotStyle "C:/Program Files/Altair/2019/hw/prefinc/post_styles.xml"
    hwi CloseStack
    I am trying to import the post_styles.xml file but it is not loading in model. Can you help to resolve the issue.
    Thanks in advance.
    Regards,
    Sanket Patil
    OP
    hwi OpenStack
    hwi CloseStack
    Thanks in advance.
    Regards,
    Sanket Patil
    Hello All,
    Any suggestions on this?
    Regards,
    Sanket
