🎉Community Raffle - Win $25
Join and Win
Composite Plate Diagram Stress along Thickness
( Hypermesh, Optistruct, Hyperview )
Good evening,
I'm performing an analysis on a composite material plate ( a simple rectangular plate ), made with 17 layers. The plate is subject to tensile and bending on the same side.
I need a graph showing the stresses variation along the thickness. But how ?
I followed:
- Measure Panel ( selected an element of the model )
- Contour
  - Composite Stresses ( s )
  - Normal X Stresse
  - Layers = Top/Bottom
  - Top/Bottom Layer Settings
     - Top Layer = Ply1
     - Bottom Layer = Ply 1
  -  Use Corner Data
  - Averaging Method = Simple
I wished to collect enough data to plot the graph by myself.
However, every ply has always the same top and bottom stress. Why ?
If you know an easier way to get this plot, please give me a proper explanation.
Thank you for the help.
