🎉Community Raffle - Win $25
Join and Win
How do I get the plane of a circle?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
In order to define a plane containing a circle, I need the center of the circle and the normal of the plane. Getting the center is simple using hm_getbestcirclecenter. I have not been able to find a means of getting the normal. If it were possible to get the coordinates of two points on the circle, I could use those with the coordinates of the circle center to calculate the normal. However, I haven't been able to find a means of getting those two points.
1 - 3 of 31
    User: "tinh"
    Altair Community Member
    Updated by tinh
    I know that there is such command ( i read it already), but I can't remember
    anway, you can try creating the circle (using *createbestcirclecenternode with last argument=1 (will create circle, too))
    and then create 4 nodes on that circle to calculate normal vector
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    It might be hm_getcoordinatesofpointsonline.
    Example:
    *createentitypanel lines 'Select line';
    set lineid [hm_info lastselectedentity lines];
    foreach coord [hm_getcoordinatesofpointsonline $lineid '0 0.3 0.6'] {
     tk_messageBox -message 'Coordinate = $coord';
    Altair Employee
    OP
    Example:
    That works perfectly! Thanks!
