🎉Community Raffle - Win $25
Join and Win
impossible displacement and no von mises strain
User: "mirko088"
Altair Community Member
Updated by mirko088
Hi, I have a problem with my model . This is my first analysis with optistruct.
By displaying the results of the analysis I get an off-scale shift, also I don't get the results in Von Mises. In the skin it gives me a value of zero while in the solid it gives me no value. What are the problems? I have attached a model and some images. The constraint is an interlocking while the forces are: gravity, centrifugal force, drag and lift.
1 - 2 of 21
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Make a simple test with ONLY gravity load?
    User: "mirko088"
    OP
    Updated by mirko088
    Hi thank you for the interest, I made the mesh again because I had connectivity errors, the problem is that I get too high displacements. I am considering the centrifugal force through the Rforce card and then I would have a lift force along Z. If I run the analysis with only the Rforce load I get a displacement of 44 mm while as soon as I also insert the lift I get a displacement of 8 meters. Where am I wrong?
