1 - 9 of
91
make a layer of quads along the weld, then you can map solid elems following them
Hi Taehwan Um,
Try mapping elements in the reverse direction (Choose elements you want match as source elements).
Thank you
Hi,
Simply make quad mesh on outer side and then use panel 2d>elem offset>solid layers to generate hexa mesh:
