🎉Community Raffle - Win $25
Join and Win
Velocity problem of drop test in radioss
User: "anqi"
Altair Community Member
Updated by anqi
Hi all,
I am working on 3 m landing gear drop test in radioss. The material is aluminum. I set it as M2. Partial model is listed blow. I cannot put the whole model due to confidential problem. I chose type 7 in self contact interface. I chose infinite plane as rigid wall, with a distance 10 mm from the bottom of landing gear. Then, I set initial velocity as -7500 mm/s along Z direction, calculate by v=(2gh)^(1/2).
blob.png.3646e7ab0ed611147bfcfca9dbaaca55.pngblob.png.8822fccb07f1ee585899f4d03237347b.png
Now results confused me. In velocity, when the bottom of landing gear impact on ground, the velocity became slower, however, the top part did not stop, retaining 7500 mm/s velocity, even if the bottom part deformed. Results are listed blow.
blob.png.0dc8a3f09a54c9e985c9413783b586bd.pngblob.png.9a5a7a12fbc2c0cafa1f741c450c35ef.pngblob.png.e03127a6fd24bf78f7e8bc0de82fd376.png
Is that right? Can anyone help me. Thanks in advance.
Regards,
ANQI
