🎉Community Raffle - Win $25
Join and Win
how to add gas force in inspire motion
User: "puneet kukreja"
Altair Community Member
Updated by puneet kukreja
I am doing an multibody dynamics analysis of Rotary compressor in Altair inspire motion. I want to ask how can I add gas force in altair inspire
1 - 1 of 11
    User: "Scott_Z_2"
    Altair Employee
    Updated by Scott_Z_2
    Hi Puneet,
    Some further clarity on your problem setup would be helpful for providing the best answer to your question, but I'll add some food for thought...
    • Pressures are not supported in motion, only force
    • If you need to apply a force, use the Actuator feature and specify the type as Force
    • The actuators have different end conditions (ball mount, fixed mount, rotate with part, etc.).  I am attaching an image here that shows an example of the different ways actuators can be treated.
    • In the current release, Inspire supports only force vs. time
    • If you need forces on multiple faces, use multiple actuators
    Again, without seeing/understanding your exact model setup, it is difficult to give you a definitive direction.  But hopefully some of the points above will help.
    - Scott Z
