Hello,
I am currently doing a drop test and the design is failing way bad than the actual object. I think this is because in actual drop test, the concrete ground absorbs certain energy. In the simulation I used RWALL which won't absorb any energy. So is there any other wall that absorbs energy?
Please find some info on RWALL.
https://altair-2.wistia.com/medias/i1ij1jnvhn
