Intersection Line/Element
Hi !
I am currently working on a macro for HyperMesh.
My problem right now is that i have a 2D mesh and some line going through many elements and i want to get the elements that are being crossed by a line.
To schematize the thing :
__l___l_l____l_____l_______l____
l l l l l l
where ' l ' represents my lines and '_' my 2D elements.
I want to write a subroutine that could do :
foreach lines $LineList {
Give me the element that the line is going through
Any ideas how to do this ?
I was thinking of creating a 1D element that would replace the line and then try to look for the intersection of both elements (1D/2D) but i can't find out how !!
Maybe with the the hm_collision function, anyone already used it ?
Thanks a lot in advance !
Clément
Thanks for your answer.
I was searching for a more direct solution only considering the elements.
But seems like you have a good solution here !
I will reduce the number of temporary surfaces to create with a hm_createmark elems 1 ' by cylinder', basing the cylinder characteristics on the nodes of my lines.
Again thank you !
Maybe try to create a temporary surface for each 2D element and look for intersection between the line and surface through the function *nodecreateatintersection ? If intersection node found you got the element and so on.
